Originally Posted by mattylondon
I have an intermittent problem when indicating right. When I move the stalk up, for right, it briefly signals left then right as normal. Then when the stalk returns to the centre it activates the convenience 3 flash left. **** it's annoying! I think the stalk is faulty and have a spare waiting to be fitted. Thankfully it only does it at start up when the stalk is first used.
You can use measuring blocks to see if the right signal command is being sent from the steering wheel module.
My thinking was the stalk when it did it first time 3 years ago.
Today was the 2nd time in 3/4 years.
If it becomes more common, I'll take VCDS with me.
[center]
06 3.0TDI Quattro:
Options:
