Originally Posted by mattylondon
Glad someone bought it
It's a straight swap with your existing module (it's next to the radio in the boot left hand side secured to the wall around the rear suspension strut). Coding will be the same as your current. It may need to be enabled from the MMI menu.
Are you sure coding is the same? I thought that you had to enable it in the hidden menu plus adjust the coding as well, I seem to remember 2 things had to be done once you had swapped the module?
