  #270
Old 8th February 2017, 01:43 PM
Thanks Sean.
Having just reread (all earlier in this thread) what you did I might just try adjusting it; maybe it is just a bit too sensitive at the moment so not always freeing up properly after gentle braking?
I did note:
The switch was showing a value of 1000 when untouched.
A VERY LIGHT touch on the pedal (engine off) would change it to 1010 but the slightest bit more and it went to 1011.
That sequence could be reversed by lifting off very carefully.
What is required to adjust it, do you just loosen the locking nut and turn it?
I assume from the diagrams I've seen that it's "above" the pedal so would need screwing "down" towards it to ensure it was in the "no braking" position.
I saw that MJ said something about it being possible to fit it in the wrong position, but was that and orientation issue or just how far in/out it was because of the two separate switches?
(I think just an in-out issue rereading carefully)
I did earlier say:
Maybe my brake switch is faulty too.....
but maybe it just needs a slight adjustment?
