Old 12th February 2017, 11:51 AM
Originally Posted by Snaggle57 View Post
I don't have vcds, just a basic code reader, but it's always worked in the past (10 b5 a4,s & a6s) I can't really warrant spending the money on a vcds kit for a 20year old car I don't really use
Now I would disagree with that, VCDS is an essential and saves you money, probably even the first time you use it.
You really do need to read the codes from the gearbox, does your code reader do that?
I'd start off by buying a cheap eBay generic cable and running VCDS-Lite in free/demo mode with it, that should enable you to see enough to check whether the gearbox itself thinks it's OK.
(You won't be able to reset errors or do full scans, but right now you don't need that)
Or you might find someone selling an old VAG-COM system, that would be all you need for a car of that vintage.
Where are you, there may be someone near you with VCDS that can scan for you?
