Originally Posted by speed_demon1978
Hi Scott - thanks for the reply. LHD meaning for example that when I open the driver door, the passenger door displays as open on the instrument cluster screen and vice versa. The mpg reading as it is also seems like it is the EU units from doing searches on the net.
As you realise, this is two questions and neither are simple to answer! You'll almost certainly need VCDS to sort it!
1) Left / Right setting[s].
Your conditions probably reflect someone messing with the car ECUs in the past. The Driver and Passenger door ECUs are identical but coded differently. Unfortunately I can't find any coding explanations for the ECUs but I have ECU HW 4E0 959 760 in both doors and mine are coded "3670112" Passenger - Left - ECU 06 and "3670126" Driver - Right - ECU 36.
2) Miles/Km
As Marcin indicates, this is relatively simple, as it is a selection off the MMI menu somewhere for the units to be used for the car. HOWEVER, if you have a fingerprint reader, Mi/km is one of the settings that is retained for each user. [As there are 4 users with fingerprint reader, this make 5 variations available, as there is also a setting that is used if the driver is not identified].
