13th February 2017, 02:22 PM
Originally Posted by JulianHicks
As you realise, this is two questions and neither are simple to answer! You'll almost certainly need VCDS to sort it!
1) Left / Right setting[s].
Your conditions probably reflect someone messing with the car ECUs in the past. The Driver and Passenger door ECUs are identical but coded differently. Unfortunately I can't find any coding explanations for the ECUs but I have ECU HW 4E0 959 760 in both doors and mine are coded "3670112" Passenger - Left - ECU 06 and "3670126" Driver - Right - ECU 36.
2) Miles/Km
As Marcin indicates, this is relatively simple, as it is a selection off the MMI menu somewhere for the units to be used for the car. HOWEVER, if you have a fingerprint reader, Mi/km is one of the settings that is retained for each user. [As there are 4 users with fingerprint reader, this make 5 variations available, as there is also a setting that is used if the driver is not identified].
Hi Julian - no fingerprint reader. Don`t actually have any idea what/where that is if I do have it lol. I don`t think I do, only have the keyless go entry/locking system (when it decides to work that is!  )
Current: MY57 Audi A8 3.0 TDI Quattro SE, Silver, Black Comfort Heated Leather, MMI High 2G, Bluetooth, Nav, Voice Control, AMI, Rear Camera, 6CD, 20 inch 9-spoke alloys [in Black], Folding Mirrors, 3-spoke S Line steering wheel + mods to come
