Thread: Tesla
Old 13th February 2017, 08:41 PM
That 75% is really interesting but it's actually a CHP (Combined Heat and Power) unit, so yes it's 75% efficient in that only 25% is "wasted" but a lot of it is used for heating.
Quite probably heating used in the refining process.
(PS I used to work for Esso and later BP and do know a fair bit about refineries)
By the way, refineries produce the mix of fuels that they are designed to produce and this can be adjusted or changed, though big changes are not necessarily easy.
Producing 19 gallons of petrol from 42 gallons of crude means little or nothing in efficiency terms, it's certainly not 19/42 (45%).
A better measure is how much total energy is in the output fuels vs how much is consumed in the process. That may be the 88% you mentioned.
