View Single Post
Old 17th February 2017, 08:58 AM
There is an earlier post on this - I had the same problem, and Ian (IT) correctly pointed out that you can also jump from the main cable (thick) connector which is in the front passenger footwell, under the carpet, by the wheel arch - a method I've used successfully, so hopefully this will work for you too.
