Old 18th February 2017, 07:55 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Julian,
I got the Handyvorb2 which allows either BT connection or a handset via the cradle.
Also got call history, dial, phone book and the ability to copy the phone book to the car.
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000007605113
Coding: 0010900
Shop #: WSC 00000 000 00000
VCID: 2C5088088FC2F64B49D-8078
4E0 862 333 x : known as "TELEFONMODUL EU" in VCDS - Original Phone prep using car hifi to talk and listen. Optional BT Motorola handset under the armrest. ECU supports Bluetooth ONLY to allow the optional Motorola Handset to participate. [Probably for back seat executives]
BT Motorola unit only allows Bluetooth connection via the Motorola handset, that's annoying.
What function does that give you via the MMI?
When you say talk and listen via the hifi, it uses the speakers from the stereo and the microphone in the roof?
Same as the others then?
[center]
06 3.0TDI Quattro:
Options:
