Originally Posted by MikkiJayne
Assuming this is resetting the dynamic shift program, I find it odd that it even needs doing tbh. Mine responds very quickly to changes in driving style, and even countryside - it knows when it's in Cornwall for example, and holds on to gears longer on the hilly bits and switches between cruising and hair-on-fire quite easily.
Edit - I wonder if its a difference between early and late software in the TCU?
I would agree that the dynamic adaption occurs over minutes rather than months, so the need to reset it confuses me.
The most dramatic case of the shift pattern adjusting I found pounding a PF S8 through the Yorkshire countryside, so I'd say that if they had it so right back then, then it probably hasn't been fiddled with since.
However - I've long been a believer that the 'S'port setting on the 2002 gear shifters is basically an override to stuff the gearbox ECU into the most aggressive pattern possible immediately, so rather than waiting a few minutes to learn, you can be sporty straight away, so arguably, the need for the dynamic learning is a bit lost from 2002 onwards when all Audis got the Sport box....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
