Old 21st February 2017, 08:22 AM
Same here .... pretty much stopped using the buttons when I upgraded to a FL S8 too.
Tip is still useful if you want to change down early for a bit more engine braking (while in 'S'), though the problem with that is you then have to move the selector to get it to go back to full auto, or wait (about a minute is it?) for it to revert back itself.
Thats about the only use I have for the Tip buttons. They also can be used when in "D" as well - if you ever care to be in D rather than S! The interval for reverting to D seems to be much less than a minute tho'.
I am not sure that this re-learning issue isnt a thread about nothing though. Yes, the resetting may well be achieved by the methods described but why bother as it then learns again (and within a few minutes accoriding to IT and MJ) your style of driving on that journey. I'm with MJ on this - if you want some fun stick it in S and if driving Miss Daisy keep it in D. It will soon decide the change points etc for you. Thats why its called DYNAMIC shift programme.
