Originally Posted by HPsauce
Fuses came to mind, but sadly the drivers footwell fuse (ideal location) for the reversing lights is shared with the automatic gearbox.
You have an S8, which means you have factory RNS-D.
The RNS-D has a reverse wire feed so that when you are going backwards, it knows to count the gala/abs wheel pulses backwards, otherwise the navigation would be hopelessly wrong if you reversed somewhere with poor GPS reception.
Pin 17 of the 26 pin connector on the back of the RNS-D, Should be blue with a red stripe. I strongly suspect it will be labelled as such on the top of the RNS-D.
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
