Old 5th April 2017, 03:29 PM
a 5A fuse in it's wiring, in that constant 12v circuit.
So while I'm at it I'll make sure any 12v take-off I use is protected by that fuse.
Done and refitted, though a bit of "readjustment" is still required behind the RNS as something is stopping it going back that last 5mm.
I now have a 12v supply, protected a 5A fuse, energised via a relay when the RNS is on (irrespective of ignition). I've moved the CVBS/RGB converter box to that and the RNS does indeed "see" a TV input all the time now, though when selected it currently says "No Signal" unless I'm in reverse.
I'm just about ready now to start testing the TV tuner in the car.
