Originally Posted by IT
he converter box should be injecting its presence onto canbus so that the RNS-D actually knows that there is a possible RGB input to switch to - Prior to you installing that box, you presumably couldn't even select TV as it knew you didn't have one connected.....
For this reason, simply hooking up RGB to back doesn't work. Many have tried and failed.....
Indeed as soon as the box is connected and powered up you can select TV, but I think the detection is actually pretty simple.
The 10-pin DIN connector on the back of the RNS is all that is needed and the contacts on that break down pretty simply into stereo audio (plus ground), red/green/blue (plus ground and sync) and two signal wires.
Those two separate signals are PAL/NTSC and Video-on. I haven't bothered measuring them, but I'd guess they are simple 5V or 12V vs 0V presence/absence, nothing cleverer.
Interestingly the TV tuner is PAL (of course) but the reversing camera comes up (brief initial display) as NTSC. I'm not sure if that initialisation display coming from the RNS or the converter box though.
How the RNS communicates with the OEM tuner, e.g. to change channel, I have no idea, but I don't think it's down that connector, it's purely for input.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
