Old 9th April 2017, 05:40 PM
A major decision is required re something non-OEM that I can't hide.
The IR receiver "magic eye" for the TV remote; it's a thumbnail-sized dark dome with a black cable, but where to put it?
I'm not bothered about using the remote from anywhere in the cabin, as long as the driver can use it (when parked, obviously ) and maybe the front seat passenger as well?
Two places appear practical:
1. The bottom left of the instrument cluster, just to the right of the clock buttons. The cable (recoloured if necessary) can run vertically down the join in the trim then behind the drivers knee panel. An easy/temporary initial fit.
2. Incorporated into the "video in motion" switch to the right of the steering column in place of the non-functioning LEDs. A bit of work, effectively invisible, but only useable by the driver.
I ran my magic eye under the rear carpets from the boot and into the space under the arm rests in between the front seats (along with the red yellow and white video input cables - in case I ever wanted to plug in an input device like a player or a video cam etc
