Old 11th April 2017, 01:18 PM
If you take the undertrays off there is a rubber pipe of around 1" dia that connects to a rigid pipe with a metal spring clip. Mine leaked there. A garage put a jubilee clip on instead of the spring clip which fixed it for a few years but is leaking again after I disconnected it to drain the coolant. That's the only place I have had trouble with. I will fix it again soon, but a PITA to get the trays off on my driveway - it'd not quite summery enough yet.
