Hi I bought mine new from Westfalia with the 13 pin socket and extra wiring kit for caravan as they don't come standard.
Fitting bar as said fairly easy wiring all fitting behind battery had to come out makes it easier. only when I put mine back that I realised that extra wires were missing.
It will need coding mine isn't and it just bleeps when reversing with caravan, everything all works just doesn't switch sensors off.
I don't have VCDS.
Don't forget bumper cut out, 13 pin folds away so nothing seen.
Would recommend they get the 13 pin genuine kit from P F Jones, I've towed for many years and always had 13pin much better than 7 pin, even if only towing trailer or for bikes.
David
