Thread: Music setup
Old 21st April 2017, 06:32 AM
You are correct, the parrot kit will not work.
The AV1 and AV2 inputs are on the TV Tuner, to utilise them you need to buy a cable set, access the TV tuner and then manually insert the pins from the cable set into the existing connector.
To get music in mine, I retrofitted the official Audi AMI which I now run a small external 320GB HDD with loads of music on it. However due to the £ to Euro situation the price of these has sky rocketed recently.
AMI may require you to upgrade the MMI software depending on the version currently running.
You can also switch out that old analogue TV unit for a freeview one, I did that last year.
