View Single Post
Old 26th April 2017, 08:57 PM
Originally Posted by A8 Ian View Post
Yes, same track both cars, same format and bit rate etc straight from one car to the other, with the 2016 S8 sounding far better...
Now part of me wandered, is this to do with the active noise cancellation. .. and is that system in some way different ... I can see the microphones in the headlining on his. Where I do not have this ...
If one has noise cancelling and the other does not, that sounds like a solid difference (no pun intended). It will at the very least reduce your perception of extraneous noise, which may enhance perceived clarity of the music.
It would be interesting to compare with B&O as well.
