Old 27th April 2017, 10:28 PM
Originally Posted by B4-Andy View Post
I have seen that article before but the movement of the steering even at low speed and the uneven wear on the pads leads me to believe it is a wrapped disk. Not sure those disks will make it back on the car mind you. Trying to source a couple of replacement front disks for reasonable money.
The ones on the car were OEM and were silly money IIRC. I looked at 8 pot Brembos but didn't trust the options for mounting brackets. Think there are Brembo drilled options available to use with standard calipers?
The rear disks made me laugh, turns out they are the same as A4 fronts
Yep, Passat and A4 vented fronts (so cheap!)
