Old 1st May 2017, 05:49 PM
a pretty good location with the aerials barely visible to front or rear seat occupants (or from outside) as they are against the black glass surround.
I've found another factor that seems to influence reception quite a lot; the way the aerial lead joins the aerial.
It seems necessary to route the lead directly away from the aerial (it emerges from the centre of a "T") for a few cm and keep it away.
So placing the aerial at the edge of a window (including the windscreen) then running the cable beside it towards the tuner doesn't work well.
(I guess the earthed outer shield interferes with signal reception if it's very close to one branch of the aerial)
My interior trim is light and the cables are black so there will be some visibility until I can figure out how to disguise or hide them.
A photo of the initial/test placement is attached .... (this is the nearside, not tidied up, offside is a mirror of this). Taking the lead inboard then under the edge of that trim works fine.
What really upsets me is not the short length of cable on show but the irreparable damage to the alcantara headlining done by an aggressive valet before I got the car :
