Originally Posted by Delboy
I suspect the valves may be stuck shut but that may be because you over pressurised the struts.
If I remember correctly the front struts are 4.5 bar max
You may need to release the pressure manually from the struts.
Thanks a lot Guys!
seems it could be this - I was able to release pressure manually
I will have to adapt the suspenion, and will post the results
...the only weird thing though, is that two valves were replaced 2 months ago...
