Old 16th June 2010, 09:30 AM
The pad wear sensor light works on a closed circuit. As soon as the pad wears through the circuit the light comes on. If there is a break in the circuit anywhere the light comes on. You can short the contact in the connecters at each wheel arch to test if its the pads or not. After that it will be a break in the wiring somewhere and you'll just have to hunt it down.
Troubleshooting guide is here.
You can bypass the circuit to switch off the light and there is a guide on Audipages showing how to do it here.
