14th May 2017, 07:32 AM
Originally Posted by Audidothat
Whilst waiting for my daughter outside of a newsagent, she returned to tell me 'my car is leaking onto the floor'.
Quick inspection showed green hydraulic fluid coming from behind the fog light.
I chanced my arm and drove the 30 secs home, by which point I need the strength of Thor to turn the wheel, luckily I do!
Anyway having stripped the wheel arch liner, the air box and fog light grill off, there is fluid everywhere.
The reservoir was empty so I topped it up and asked a friend to see if he could see a leak when I started the car up.
He quickly told me to stop as it was spraying out under high pressure.
So it cannot be the usual return pipe issue, correct? It needs to be pump side, any ideas before I stick it into a garage?
Just hoping it isn't pump failure but not sure why it would spray everywhere if it wasn't!
Sorry forgot to add, there was a terrible burning smell, almost electrical, could that be the pump working over time?!
