Originally Posted by notorious
Very interesting. Did you manage to remove the old rings then?
Yeah, I just used a large drill bit and (very carefully and slowly) removed the fixings from the rear, which essentially comprise of plastic posts that have been melted behind to hold it in place. You just have to be careful the drill doesn't snatch and go straight through. I suppose you could use a hand drill or countersink tool instead. There's enough left of the fixing posts that you could refit it with a little glue later, should you need/want to for any reason.
