Thread: Air con
Old 27th May 2017, 04:17 AM
B@fink B@fink is offline
I relented and took it yesterday having gotten a voucher code. £39 sheets all done. Takes an hour, they can only use the high pressure port so it's drained, vac tested and then has to be filled into the high side which I assume slows it down a bit. They recovered about 330grams from the system (which needed 775g put back in) so it was half full. Not bad, it's the first time it needed filling in 8 years and was still making 15-18c air from the vents (so knocking 10c off of ambient). Yestderday it was making 9c and setting it to 18 on climate had it slowing the vent speed after 5 minutes of running which was rather pleasant in what I assume is the sum total of this years summer ��
