Without buying new there is no guarantee that any used cluster will not have the same problem. The DIS LCD screen failure is a very common one and given the age of these cars now then chances are that the fault may exist on any used cluster.
You can buy the LCD panels new, and its not difficult to swap them over if you are good with a soldering iron.
