Old 7th June 2017, 11:13 AM
Here's the result of the scan, clean modules removed:
VCDS-Lite Version: Release 1.2 Wednesday, 07 June 2017, 11:10:02:65169
Address 01: Engine Labels: 4D0-907-560-AVP.LBL
Controller: 4D0 907 559 AA
Component: 4.2L V8/5V G 0002
Coding: 10753
Shop #: WSC 02629
VCID: 6DADB4263489
WAUZZZ4D63N001043 AUZ7Z0A2019960
7 Faults Found:
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16690 - Cylinder 6: Misfire Detected
P0306 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Controller: 4D0 907 389 E
Component: ABS/ESP allrad D57
Coding: 08397
Shop #: WSC 02313
VCID: 31156856E831
1 Fault Found:
01119 - Gear Recognition Signal
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D17
Coding: 16235
Shop #: WSC 02314
VCID: 42F7379A5D97
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor Labels: None
Controller: 4D0 951 177 B
Component: Innenraumueberw. D06
Coding: 00001
Shop #: WSC 00000
VCID: 28238532DBEB
1 Fault Found:
01350 - Alarm via Theft Warning System; Rear
35-00 - -
End --------------------------------------------------------------------------------------------------
I cleared the engine codes and ran it for a few seconds while stationary, none returned, but....
