Old 22nd June 2010, 05:56 PM
Originally Posted by A8L Chick View Post
This is what my car is throwing up at the moment... Any ideas which part(s) to replace
She's running fine (power wise) just the orange light on the dash showing engine fault??
Only thing I would say is she seems to have aquired a "bass line" One thing I might add is the car has good rythem
Many Thanks Bex
005504 - Throttle Actuator (Bank 1): Malfunction
P1580 - 008 - Implausible Signal
Freeze Frame
Fault Status: 01111000
Fault Priority: 0
Fault Frequency: 6
Time Indication: 0
Date: 2010.06.12
Time: 17:07:35
Freeze Frame
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 12.31 V
Duty Cycle: 82.9 %
004203 - Throttle Valve: Stuck or difficult to move
P106B - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 254
Time Indication: 0
Date: 2010.06.18
Time: 22:11:34
Freeze Frame
RPM: 777 /min
Torque: 93.6 Nm
Voltage: 4.080 V
Duty Cycle: 61.2 %
Duty Cycle: 7.5 %
P1580 is
P1580
Throttle Position Actuator (V60) dirty/stuck/faulty
P106B is
P106B
Could be -
1) Wiring/Connectors from/to Throttle Body Control Module to Engine Control Module faulty OR
2) Throttle Body Control Module Damaged and/or Moving Difficulties
Click on the code links for a fuller explanation in both cases
HTH
