Old 8th June 2017, 06:40 AM
Mossyboy1978 Mossyboy1978 is offline
OK will do. Just out of interest how easy is it to replace the MAF? Job for the home mechanic or novice?
Fair enough, but make sure the MAF is tested before assuming that's a problem. With VCDS (and other tools) you can check/log the readings.
Also, if your F125 switch is playing up you can get very odd behaviour as the ECU's don't know what gear you're in.
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust.
