View Single Post
Old 12th June 2017, 06:42 AM
I thought ceramic rotors were supposed to last the life of the car...
Clearly not - bloody expensive for a consumable item!
Someone should make steel discs of the same dimensions as the ceramics for a direct fit replacement. Even at a few hundred £ it would represent an affordable and economical solution to worn ceramics.
Is there a recoating solution?
How big are they, 420mm? I know you can get 400mm discs on the D4 which *may* use the same caliper (with different pistons?), but they ain't cheap either.....
http://audisrs.com/AUDI_S6_S7_S8_A6_...bout69435.html
