Old 12th June 2017, 02:36 PM
1781cc 1781cc is offline
I've got one for just that reason, 4 seat soft to with a V8 and a clutch is perfect for it
That said, they are not without potential issues. mainly timing chain related on the BBK engine, plastic tensioners/sliders that fail and bork the engine = lots on ebay as breakers.
Clutch and DMF can take some stick, but if they fail = £££
I've had three S4s, each has needed a new starter!? Can be done in situ, so not the end of the world.
Usual B6/B7 issues possibly compounded by front end mass, top suspension arms semi-consumable and can be a PITA.
Auxiliary radiators can seep and leak due to corrosion, front end off job.
Oil pressure sensor went last year, changed in situ thanks to my "girlish" hands.
On the soft top the motor tends to fail, easy and inexpensive to have refurbished though as it's just the bushes.
Auto is more of a cruiser than the manual, lower RPM on the motorway. Milltek catback frees up the V8 soundtrack, but the non-resonated can be boomy on the auto (but the manual is okay as you can pick another gear).
Xenon headlights will be rubbish, unless the reflector bowls have been changed - I fitted new projectors and all good now!
Look out for corrosion, mine will get a pair of new wings this year (assuming it doesn't end up on ebay with a borked engine )
I've had two B6 S4 Manuals and all of the above is perfect advise.
Only other thing I would add is check for inner front arch rust, broken clips on the armrest cover and the operation of the inlet manifold flap which can stick and cause 4K rpm misfires.
You can also fit Milltek race downpipes that become full decats and will need a remap to bypass the sensors, I did this on my first one and Minhea from MRC logged 371bhp on their dyno. If thats too drastic, you can gut the pre-cats (piggies) and that helps free up a little power for free.
These engines respond well to LPG if thats your thing, I ran one of the two on a BRC system for 2 years, cost peanuts to run and when the donut tank in the spare wheel well ran dry it auto-switched to petrol seamlessly, its essentially a dual fuel. Incidentally, a dual fuel with the piggies gutted passes the MOT with a probe in because it runs cleaner and the cats "look" present but actually are free flowing
Good cars, part of my desire for an S8 was because it was a natural step up from the S4 and to all intents and purposes behaves like a bigger S4 with more refinement.
AudiSRS and RS246 have good dedicated sections on these cars over there.
Finally, timing change rebuild can set you back up to £3K and if you get a good one, the sky is the limit tuning wise but it wont be cheap - JHM in the US are world leaders for this platform and have supercharged several with devastating results.
