Originally Posted by mattylondon
VW / Audi's will display a fixed 90c on the gauge when the actual coolant temp is between a range. So you can't tell the true temp from the instrument cluster. Have you VCDS or OBD11? These will be able to read the true coolant value.
I don't know at what temp the rad fans will kick in on the D2, but on a D3 it's 100c
The D2 viscous fan is obviously always running but the electric fan cuts in at 94degC. I had an overheating issue a few months back and sat and watched the displayed temp and noted when the fan cut in. Later I monitored with VCDS which, as stated, is a very useful tools here and there was a reasonable alingnment with the displayed temp. The 'stat should start opening at apprx 87DegC and be fully pen at 102degC.
