Originally Posted by ainarssems
Rough calculations at this point show that I will be using £27 per month in electricity and getting back about £19. Decent graphics card should improves this but I have to run numbers first.
MikkiJayne how do you get business rate for electricity, is it as simple as registering company and then doing energy contract?
How are you calculating your electricity usage and which card is that?
Certainly some cards are far more efficient at mining than others. If you're building a rig specifically for mining or it's a PC that wouldn't normally be on 24/7 you do need to take the rig 'overheads' (CPU, drives, etc) into account when calculating the running costs. If you can't make use of the heat generated or you want to get electricity usage down to a minimum, building a larger multi-card rig might make more sense. The rig overheads will be greater when mining with just a few cards.
Also, depending on which card you use, you can usually make some adjustments to improve efficiency. For example, with the AMD cards you use the supplied AMD utility 'Wattman' to reduce the GPU frequency by about 15-20%. This has no significant impact on mining performance yet reduces power consumption from about 160W to 100W per card. For comparison, I have a 2 card AMD rig (RX 480) that consumes about the same as yours (~£27 per month) but makes about £100-£150 per month.
So far I have set up bitcoin wallet now and Nice Hash mining but my Kaspersky Internet Security has gone viral. after pressing allow like 200 times it pops up again like every minute.
It only uses 5% of my old CPU na d about 50% of 8GB of RAM.
Kaspersky is probably just triggering when NiceHash switches algorithms or makes new network connections. While it's best to experiment initially on an existing system, you'll have better results running the cards on a dedicated system without such aggressive antivirus/firewall software.
