Is there much performance impact from running an x1 to x16 riser? I've got 1x1 and 1x16 on this board so I could at least get another 960 on it. The Xeon board has 2x16 and 2x8 though so I could get four on that if I can persuade it to work. It might have just needed a clean OS install. Not sure there's much point powering a pair of Xeons though since the Core2 Quad on this machine is just idling.
For mining purposes there's no difference between x1 and x16. Mining only requires a single PCIe lane. As I understand it, there's relatively little data travelling to/from the card when mining; the card spends far more time doing the work than it does receiving work or returning hash solutions.
Depending on which Xeon CPUs you have there, you can probably mine with those too. You won't make a lot from them but they'll probably cover their electricity costs (just). Unlike GPU mining though, other applications may suffer reduced performance while CPU mining.
I often run NiceHash when I'm setting up new servers for customers as a kind of soak-test. It gives the CPUs, fans and PSUs a good workout and confirms everything is stable before I start installing and configuring everything. I have a HP ProLiant DL360p Gen8 on my bench right now. Here's a NiceHash screenshot of its workout a couple of weeks ago:
I calculated the electricity usage to be a little over £1 per day, so I was making a small profit.
