Originally Posted by ainarssems
I don't think I could go over 10kW which is 40A as I only have 60A supply to house and need to leave spare capacity to run other things so going beyond that would require supply upgrade or move to/rent other premises.
I wouldn't worry about it. The HRC fuses at the supply point have a fusing factor of at least 1.5 times the rating and you are entitled to an 80A supply as standard anyway. So if it blows your friendly local electricity company will come and fix it for you and will probably fit whatever they have 'in the van' which could be anything from a 60-100A
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
