Originally Posted by H-M3
Sorry Matt, are you saying that if you have a tv tuner from factory then you can fit these without any other parts?
That reply was explaining that you can't add a TV without upgrading the MMI control head.
But having a TV means you can do:
1) A cheap RVC install of adding it as an AUX video input and manually turning it on. (About £40 install)
2) Doing the OEM RVC install, Del has a retro fit guide on here. (About £300-£400 install)
Without the TV, adding the interface, like John and Ray have, will trigger the RVC when reverse is selected. (About £200 install)
