Old 25th July 2017, 04:03 PM
Well, I really don't understand this.
Opened up the connector, all looked good, joined it up again and nothing.
A bit of wiggling, still nothing, then just moved it a bit to try and prod the motor and suddenly it's all working.
Currently it's back in it's mounting clips, appears properly joined, and is all working OK. Trouble is there's almost no slack to work with and just a small gap through the intake flaps to work in.
My suspicion is that somehow one of the (thick) cables isn't terminated properly onto the contacts inside one half the connector as the mating surfaces look fine.
I think I might buy a connector pair, make up a short lead to bridge the two halves and try to work out which side is suspect.
