Old 28th July 2017, 04:08 PM
Originally Posted by Dubbs View Post
I don't have any issues with the BT in the car right now (aside from Siri getting confused now and again which can confuse the BT in to whether it should activate or not) so my intention is to:
1. Run CD1
2. Run CD3
3. Remove CD player and fit AMI in its place
4. Check functionality
5. Run CD1 and CD3 again to see if subsequent updates apply to the AMI module newly fitted
In fact - if it all works after point 4 then I'm likely to just leave well alone :-)
Looks OK at first glance but 5 won't work as you need CD drive and AMI at the same time.
However, I thought you said "I have ordered the 2G External device AMI 4E0057785F". Check the label and I think that level will be at V850. If it is, that's the latest level and you don't need 5 anyway
BTW, 1 & 2 should say "Run CDx until no updates are indicated"; to make sure there are no further updates on a CD. I vaguely recall 5150 updates some MMI screens second time ...
Julian
