Old 3rd August 2017, 01:58 PM
Thanks Mark, I like the logic, but it means hacking into cables or connectors to get readings and it's all weatherproof connectors in that area, so I'll try the "plug and play" option first.
I'm guessing that the thin wires running off the thick power feeds near the beige connector are probably to measure the voltages as part of the HVAC control system and the extra yellow/red wire is a control signal to the "hedgehog". I would presume it's fins are purely for cooling what is effectively a variable resistive load.
