Old 5th August 2017, 08:32 AM
I am not a gambling man but considering your car has solar sunroof I would bet that it is blower motor that has worn out.
Nor me, and I initially thought the same, but the evidence does somewhat point away from that. Not least because disturbing the connectors in the air intake plenum has effects.
For example, at the moment it is ticking over slowly with an overcast sky, no direct sun. Not been used for a couple of days.
If it was worn similar to yours I would expect it to stop on the worn section and not restart (especially with a low voltage solar input) without being disturbed, but mine seems different. Hence my suspicions of connectors/wires and damp/movement/temperature or similar factors.
I'm collecting a few cheap bits and pieces to enable me to diagnose it better. The whole lot will cost less than an hours labour at a garage so worth trying.
I've also been using the "REST" function as a handy test and noticed something about that; it limits the fan speed to 1, 2 or 3 bars only.
(I've never, ever used it and have anyway disconnected the auxiliary coolant pump)
