Originally Posted by notorious
I'll have to do the same procedure soon. There is a "breather hole" under the yellow turn signal bulb. For some unknown reason some water got through that hole and now I've got some ugly stains behind the front element on the lower silver part.
I think there was a writeup how to remove the yellow side marker for these headlights for US cars. There were pictures, but I cannot find it...
Question: if I remove the front element, will it stay in place good enough, so I won't have moisture coming from outside? Is there a gasket between front element and the headlight that I should get before the surgery? I'm worried that I won't be able put the front element back in 100% sealed way..
Is this what youre looking for?
Clear Corner Marker Upgrade
