Originally Posted by mannyo
Take the easy options first.
Are you sure there is screenwash in the tank, my headlight washer motor does not work when the screenwash is low for example.
Are the jets blocked, I seem to need to clear mine on a regular basis. Only on the Audi though, the Volvo is always fine.
I think this is the case for headlight washers, they wont come on if you are about down to 1/3 of the tank, windscreen pump will carry on.
Had a similar problem and new pump solved it
