Old 13th September 2017, 09:10 AM
Tomson Tomson is offline
Honestly, I must finally get around to understanding the wiring diagrams. I must say that I am struggling to understand them.
I did find this on posted by Audinutt on Quattroworld that suggests this is the Pin layout for the connector. (attached) The diagram is labelled as from a 2000 S4, but I assume original poster knows he stuff!
If I was taking this as my reference I would use the rear line levels left and right to connect to my left and right on the RCA centre cable, and connect the shielded cables from both RCA to the Line Level common ground. I would also use the switched power as a feed for my remote turn on.
Does this sound about right, makes sense in my mind anyways.
