Old 19th September 2017, 11:31 AM
Yes, I was pretty sure that the seal I removed was the same thickness all round.
The stuff I've replaced it with is a bit like memory foam and shows a clear marking from the bonnet. From that it's obvious that the gap is maybe as small as 5mm or 6mm at the back but probably 12-15mm at the front!
The foam on the recirculation flaps in the intake is also quite tatty, but I'm not too bothered about that.
