Old 19th September 2017, 01:25 PM
New seal with extra layers!
(The transparent pipe is my pre-installed tube for draining the scuttle )
The sharp-eyed among you may notice that the trim around the wipers is misaligned; I only noticed this recently after having that car for 4 years!
A job for another day, it needs to come off and be refitted properly; I understand there's a tongue that should go into a slot but probably hasn't raising the whole thing be a few mm in the centre.
That also allows more/larger crud from the windscreen to flow down into the scuttle area, adding to the blocked drains issue.
