View Single Post
Old 19th September 2017, 04:05 PM
The bracket should be threaded so the M6 bolt goes through the plastic trim and straight in to the bracket.
If its previously been bodged though it could be that the original bolt seized and the thread has been broken or drilled out. If so, an M6 speed nut such as N90168604 would do the job instead
As MJ states, the bracket is threaded and (with luck) the M6 bolt with washer should just go straight in. The m6 bolt is overall 35mm in length (30mm threaded portion).
