Thread: rusted noise
Old 30th September 2017, 09:49 AM
erubus erubus is offline
Could it be a noise that can be described as an owl hoot? Is the car fairly high mileage? If so is likely known issue with the gearbox which requires replacement of the oil - ie full flush and replacement with a different grade of ATF, lifegaurd8 or some such. I believe the noise is the Torque converter clutch slipping. Is it particularly prevalent going in and out of third gear?
