Saturday,30,September,2017,13:16:26:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WAUZZZ4E65N002074 License Plate: T22KRL
Mileage: 187180km-116308mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1D 1E 25
28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 66 67 72 76
77
VIN: WAUZZZ4E65N002074 Mileage: 187180km-116308miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
66-Seat, Rear -- Status: Cannot be reached 1100
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 07C-910-018-BHT1.lbl
Part No SW: 4E0 910 018 HW: 4E0 906 018
Component: 6.0L W12/4V A ª0110
Revision: -------- Serial number: AUX3Z0D4341645
Coding: 0011773
Shop #: WSC 00353 210 62620
VCID: 5C52777F5F24D7F2F9A6A1-8008
No fault code found.
Readiness: 0000 1000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 J HW: 09E 927 156 A
Component: AG6 09E 6,0L4V RdW 0060
Revision: 00000001 Serial number: 0037043
Coding: 0000001
VCID: 2ABEE1A745F07942BB9A87-807E
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 C HW: 4E0 614 517 BD
Component: ESP 5.7 allrad H44 0330
Coding: 0007637
Shop #: WSC 12345 000 00000
VCID: 23A00C8322DAA80AF85CD2-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D4341645
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 585A6B6F2B1C3BD2DD4E9D-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 72
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H01 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063968
Shop #: WSC 00000 785 00200
VCID: 24A20F9F27D4AF328156D9-8070
2 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 186272 km
Time Indication: 0
Date: 2017.07.03
Time: 01:14:26
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Date: 2005.01.01
Time: 00:00:00
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300FF047536342
Coding: 0000002
VCID: 3A9ED1E7B550C9C2CB7AD7-806E
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 318EG047506302
Subsystem 3 - Serial number: 7405.05.040000000000010069ÿ
Subsystem 4 - Serial number: 010069ÿ
2 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 31
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 11:02:00
01319 - Control Module for Distance Control (J428)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 4
Reset counter: 32
Mileage: 187181 km
Time Indication: 0
Date: 2017.09.30
Time: 11:11:07
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0300
Revision: 00000025 Serial number: 00000000046407
Coding: 0389369
VCID: 1BD034631AAA90CA302C7A-804E
4 Faults Found:
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 20:01:56
Freeze Frame:
Temperature: 20.0°C
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 20:01:56
Freeze Frame:
Temperature: 20.0°C
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 13
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.28
Time: 17:44:22
Freeze Frame:
Voltage: 12.70 V
01854 - Heated Seat; Front Right (Z46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 69
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.29
Time: 10:31:19
Freeze Frame:
Temperature: 14.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 J HW: 4E2 955 113 B
Component: ILM Fahrer H12 0190
Coding: 0133121
Shop #: WSC 02313 785 00200
VCID: 2F88F0B37E121C6A6CE45E-807A
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0040
Coding: 00141886
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000000 Serial number: AUZ5ZBC1015724
Shop #: WSC 00000 000 00000
VCID: 1CD2377F1FA497F2392661-8048
1 Fault Found:
02084 - Component Protection
Freeze Frame:
Fault Priority: 4
Fault Frequency: 254
Reset counter: 119
Mileage: 275443 km
Time Indication: 0
Date: 2017.03.02
Time: 17:53:11
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7101465
Coding: 0000001
Shop #: WSC 02152 785 00200
Address 11: Engine II Labels: 07C-910-018-BHT2.lbl
Coding: 0011773
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041218
VCID: 25A4129B2CEE563A9648CC-8070
2 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10110100
Fault Priority: 5
Fault Frequency: 5
Reset counter: 71
Mileage: 187176 km
Time Indication: 0
Date: 2017.09.30
Time: 00:44:00
Freeze Frame:
Temperature: 20.0°C
Voltage: 12.67 V
Bin. Bits: 00100000
01044 - Control Module Incorrectly Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 5
Fault Frequency: 6
Reset counter: 32
Mileage: 187176 km
Time Indication: 0
Date: 2017.09.30
Time: 11:01:00
Freeze Frame:
Temperature: 18.0°C
Voltage: 11.14 V
Bin. Bits: 00100000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0430707
VCID: 63204C83625AE80AB8DC12-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112151
VCID: 6524529B6C6E963A56C80C-8030
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 931 E HW: 4E0 920 931 E
Component: KOMBIINSTR. VDO H70 0400
Revision: D01 Serial number: AUDID3E5000168
Coding: 0032443
Shop #: WSC 00999 444 64523
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 B
Component: Gateway H07 0070
Revision: 07 Serial number: 15004048120502
Coding: FEFFFFFC3B7D04
Shop #: WSC 00720 210 86425
1 Fault Found:
00462 - Control Module for Seat Memory; Rear (J522)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 42
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:35:57
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E2 905 218 B
Component: FPI_1 H01 0010
Revision: 01000101 Serial number: 11042005084300
VCID: 1FA800730EB28CEADC040E-804A
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.27
Time: 20:03:40
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 0
Reset counter: 70
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:31:32
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 010000
VCID: 2BB0E4A34A0AA04A408C8A-807E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 32
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 B
Component: KLIMA-STG. FOND 015 0220
Revision: 00000018 Serial number: 00000000026849
Coding: 0000000
VCID: 612C468B7846FA1AAAF078-8034
2 Faults Found:
02291 - Control Module for Seat Vent; Rear; Driver Side (J674)
02292 - Control Module for Seat Vent; Rear Passenger Side (J675)
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 00353 210 89229
VCID: 28BA1BAF5BFC4B52ADAEED-807C
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0010
Coding: 4063982
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 186272 km
Time Indication: 0
Date: 2017.07.04
Time: 00:30:41
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353FY047523897
VCID: 3B90D4E3BA6AF0CAD06CDA-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000413900087
Coding: 0036070
VCID: 1DD43A7B04BE9EFACE1814-8048
2 Faults Found:
00211 - Control Circuit for Rear Illumination Lights
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 28
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.23
Time: 00:55:00
02138 - Control Circuit for Front Right Interior Lights
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 0
Fault Frequency: 3
Reset counter: 71
Mileage: 187124 km
Time Indication: 0
Date: 2017.09.28
Time: 17:44:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRMH01 0060
Coding: 0032751
VCID: 20AA038F33CCB312E57E35-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040406080130
Coding: 0004857
VCID: 27B8189356E2442AA4B4E6-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000003257
Coding: 0000017
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000042258
Coding: 0010101
VCID: 1ED63D7709B885E2D7121B-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRMH01 0060
Coding: 0032751
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000631
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000003
VCID: 622E49877D40E102B3EA6F-8036
1 Fault Found:
02235 - Stationary Cornering Lamp (Left) (M51)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 70
Mileage: 187128 km
Time Indication: 0
Date: 2017.09.27
Time: 19:20:35
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304FS047595508
Coding: 0000001
VCID: 318CF6CB68260A9A7AD048-8064
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 D HW: 4E0 919 148
Component: R0078 TVhybridTuner 0440
Revision: R0H06000 Serial number: 76300800403102
Coding: 0000303
Shop #: WSC 31414 790 00001
4 Faults Found:
00863 - Antenna 1 for TV (R55)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 21
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:48:33
00864 - Antenna 2 for TV (R56)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:48:31
00865 - Antenna 3 for TV (R57)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 19
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:48:31
00866 - Antenna 4 for TV (R58)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 21
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:48:31
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000002193
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 350117H281
Coding: 303030393135313035444C56413033353031313748323831
Shop #: WSC 12345 128 00289
5 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Date: 2017.09.30
Time: 01:39:22
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 01:58:26
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 01:58:36
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 01:58:46
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 71
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 07:56:31
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0032751
3 Faults Found:
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 221
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.08
Time: 10:47:56
02130 - Interior Door Lighting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 72
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.17
Time: 18:43:08
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 68
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.20
Time: 10:43:30
Address 66: Seat, Rear
Cannot be reached
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000403240081
Shop #: WSC 12336 024 394758
VCID: 3686C5D781482DA22F2203-8062
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0032751
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 221
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.08
Time: 10:47:56
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 68
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.20
Time: 10:43:30
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730413301313
Coding: 0101108
VCID: 21AC068B38C6BA1AEA7038-8074
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005025638
Coding: 0010900
Shop #: WSC 02335 758 00200
End-------------------------(Elapsed Time: 04:06)--------------------------
