Some rather strange faults there. All over the place date and time wise.
I would do as Sean (steamship) suggested, clear all the faults and start again, but this time time clear manually one controller at a time. If any of the controllers fail to clear all it's faults, go back to that controler and try again after you have cleared all the others. I have found on occasions that the controllers have reported the faults found by other units, causing some confusion. Simply put; knickers in a knot syndrome.
Try and not give up, it can be very frustrating. Remember before computers came along all these problems would not have been "found" and logged and you would have been happily driving around in ignorance. Now you are on a steep learning path.
Good luck with it.
